TwinTurbo.NET: Nissan 300ZX forum - I've been running a dual fuel pump setup for awhile
Subject I've been running a dual fuel pump setup for awhile
Posted by The Devils Z on July 09, 2014 at 3:17 AM
  This message has been viewed 283 times.
In Reply To That's odd..... posted by 280ZuL8r on July 08, 2014 at 10:28 PM
Message now --it doesn't look like your passenger fuel rail is setup directly against the FPR. It looks like it's indirectly connected via the Y fitting off the fuel filter. I can tell you that if this is true, your rails will see different fuel pressures. Does it Y back before the fuel pressure regulator as you mentioned ?
You don't need independent return lines from each rail. You should connect at the front of the rail via OEM and have 1 return line from driver's fuel rail to the FPR.
=============Sig begins here================
The Devils Z.com
800 rwhp dyno
View Me! Disclaimer : Not Safe For Work !
Kid :" Those old guys drive that way ?"
Witness : "Yeah, I rode behind them at ZNationals 2010 on these back roads leaving the track day and they were foot in. They ran into the curves w/no brakes and didn't lift!"
- Hampton Inn parking lot at ZNationals 2011 -
